3' custom
Old Jun 11, 2007 | 06:09 PM
Gstfat's Avatar
Default 3' custom
what do you guys think about a 3' custom exhaust,do any of you guys have one and does it sound good?sould i cut the catalytic off or should i keep it on???give me good suggestions
Old Jun 11, 2007 | 06:30 PM
Dusty Eclipse's Avatar
Default RE: 3' custom
Id clear the cat... but if you remove TOO much of the back pressure youll actually LOSE power. Remember, you have a turbo charged car, it depends on its exhaust.
Old Jun 11, 2007 | 07:18 PM
DSMTalonAWD51's Avatar
i dont think you can remove too much back pressure in a turbo car, its already forcing air through the exhaust housing fast enough, too big really only becomes an issue on an NA car. Stock or not removing the cat makes more difference than any other part on the exhaust. Just remember its loud, smelly, and illegal. But as for your 3 foot custom exhaust, that sounds pretty big to me...
Old Jun 11, 2007 | 08:27 PM
Gstfat's Avatar
its 3 inches,so should i cut the cat off???? yes or no????with an obx evo2 turbo muffler.
Old Jun 11, 2007 | 08:54 PM
tjbiker031's Avatar
yea you could or just spend the few bucks since its already a custom exhaust and get a universal high flow cat.....just a thought
Old Jun 11, 2007 | 09:12 PM
BlackMurcielago's Avatar
' is feet
' is inches
Hence 6'2' for height
Old Jun 11, 2007 | 09:30 PM
cuting a cat is ghetto, especially since it has bolts. buy a strait pipe if you dont want it, but id not even worry about it until you upgrade your exhaust all together. ps, your gona want that cat when you visit the smog ref
Old Jun 11, 2007 | 10:07 PM
sk8dudety's Avatar
yea cutting your cat off will make your car's emissions illegal, and you need to keep that legal in order for it to pass e-check and to renew your plates... just buy a high flow cat or leave well enough alone
Old Jun 11, 2007 | 10:32 PM
where are you getting this custom exhaust done. Make sure that they can do 3" MANDREL bent piping. Because alot of people will only be able to do up to 2.5". Just my 0.02 cents
Old Jun 12, 2007 | 12:26 AM
2slow's Avatar
there was a write up in import tuner on removing the cat or going w/ a high flow cat the difference between the test pipe and the high flow was one hp
going w/ a high flow will save you a ticket but then again no cat is cheaper but still illegal
