420a 2.4
Old Feb 7, 2005 | 02:26 PM
Htes_2's Avatar
Default 420a 2.4
Can anybody tell me about swaping the 2.0 420a block with a 420a 2.4 block? what problem are there? I heard something with the RPMs and the hood space. I have a 98 eclipse... Has anyone done this before? How much work would be involved?
My Block has a stratch in it and i need two new pistons, anyone have any idea on what I could do to fix this and any idea what the cost would be?
Old Feb 7, 2005 | 07:45 PM
SpyderGS's Avatar
Default RE: 420a 2.4
The 2.4l block will mostly bolt right up. Depending on which vehicle you acquire it from, you may need to modify the engine mounts slightly. The RPM problem is just that you can't rev the engine as high as the 2.0l due to the extra long stroke. Redline should be around 6500rpm, which is only a 500rpm difference....not really a problem. The reason for that is because the crank and rods aren't the strongest units in the world, but if you upgrade you'll be fine. Basically it's a drop in procedure, however easy that may be for some, it may prove difficult for others. Just get as many people as possible to help you with the swap, that way atleast someone will recognize any mistakes...hopefully.
Old Feb 7, 2005 | 07:54 PM
Htes_2's Avatar
Will putting a 2.4l block on my car give me more hp or anymore more at all?
Old Feb 8, 2005 | 09:09 PM
SpyderGS's Avatar
It' will give about 10-15hp if you keep the CR the same, but will enhance the torque curve quite a bit.
Old Mar 12, 2005 | 04:27 PM
zoomtymes2's Avatar
what year 2.4?
Old Mar 12, 2005 | 08:03 PM
get435's Avatar
the 2.4l has 1 more hp than the 2.0l and it should be a 4g64 not a 420a.
http://www.dsmtuners.com/model-guide...eclipse2gb.php\
i beleve the 2.4 was a 95-99 i know for sure it is in 97-99. in 95 there was no spyder so i think there wasn't a 2.4l but not sure on the 95 thing.
halfasss101
Sep 4, 2007 02:35 PM
rucujo
Aug 30, 2004 01:21 AM
forza
Jan 10, 2004 02:33 PM
LowCloud
Jan 5, 2004 05:25 AM
kdombrovski
Jul 10, 2003 02:49 PM
