420a
Old Mar 21, 2010 | 07:06 PM
JBender's Avatar
Default 420a
im 16 and im looking into getting a second gen eclipse gs. i just dont have to money right now to pay insurance on a gsx, maybe in the future, along with an evo . but built right with a good turbo set up and built engine with all top shelf performance parts how much power is capable out of a 420a. im not scared to put the money into the engine over time and my dad is a mitsubishi master elite tech for 17 yrs now.
Old Mar 22, 2010 | 09:16 AM
seriously the insurance cannot be much more between a GS and GSX. Your way better off getting the gsx. You start with a much better motor and base and having AWD. The cars are so old now that i just cant see the prices being all that different.
But you can do to a 420a as much as you want as long as money is not an option. But how much can you really afford to do if you dont even have the money to get insurance on a GSX. Because the 420a will take a good amount of money to make quick and you will have less reliability as you do with any car that gets modded. Also you know in order to get the most out of that engine you will need to rebuild the whole internals. I would get a quick quote on the GSX before you waste the time and money on a 420a.
And ask around. Everyone you talk to that buys a 420a will say the same thing. "I wish i just bought a GSX first"
Old Mar 27, 2010 | 08:09 AM
Eclipze's Avatar
Well said. Get the GSX if you can; let the GS be a daily driver.
Old Mar 28, 2010 | 06:44 AM
B420a's Avatar
Dear everybody,
Do not be angry how I break the English language,
I ask an apology, if onto bad place I would write,
I would like to share my story with you.
My car single Mitsubishi Eclipse 99 (420a) non turbo)
Starts difficultly every morning, and the engine drips oil at the crankshaft,
I decided it in such a way that I resume his engine because of this,
I secure components difficultly since I live in Hungary,
My components Ebay I bribe it, a little bit heavy for me, because the transport is expensive here,
I lay these components get in the car:
OBX Radiator Hose
Mopar thermostat
MLS full gasket set
TopLine Intake exhaust valves
HY-Lift Johnson lifters
TopLine Hydraulic Tensioner
Topline oil pump
Gates t246rb timing belt
GMB water pump
Tensioner (made in Japan)
Idler (made in Japan)
Cometic head gasket
TopLine head bolts
Wiseco pistons 10.5.1
Eagle Rods
Clevitte77 main/rod bearings
Walbro gss342 fuel pump
Fuel Pressure Regulator+Gauge
New fuel filter
Engine Motor Mount Inserts kit
AEM Short Ram Intake 22-430r
OBX Cam Gears
OBX Spark Plug Wires 10.3mm
OBX Spark Plugs iridium r200
MSD ignition
Fram ph16 oil filter
Freeze Plug kit
Bomz Crank Pulley + gates belts
New Crank Pulley Damper Bolt
Megan Strut Bar 3set
The car will not be turbo onto equal one,
It would be liked yet Arp screws , but do not find for an acceptable price
I would have a couple of questions to you:
Necessary somebody else yet into him to lay into the engine my list without that let him be good ?
And ECU gets it over with then to shake hands the 10.5.1 piston-t?
What you know TopLine oil from a pump , because I read bad ones from him ?
If there is something good for somebody his component ,it you're welcome I would buy it.
Your answer greet.
Old Apr 6, 2010 | 05:00 AM
DragonRacerX666's Avatar
Default .......
Originally Posted by B420a
Dear everybody,
OBX Radiator Hose
Mopar thermostat
MLS full gasket set
Topline oil pump
GMB water pump
Cometic head gasket
TopLine head bolts
Eagle Rods
New fuel filter
OBX Cam Gears
MSD ignition
Freeze Plug kit
Your answer greet.
wtf is that...
Old Apr 6, 2010 | 07:07 AM
^^^^hahaha, ditto
Old Apr 7, 2010 | 11:13 AM
B420a's Avatar
Hello everyone,
What were you not worth? Is what I wrote trouble with it today?
I are in only so much that these will be the components into the car,
And a pair was my question,
My English knowledge very bad,
The car single Mitsubishi Eclipse 99 (420a)
You bring my questions:
-ECU can put on airs with it then the pistons with a bigger pressure ? (Factory compression 9.6.1 , Wiseco piston 10.5.1 )
-We your opinion the top line oil from a pump? ( I did not read good ones from him)
Your answer greet,
Old Apr 10, 2010 | 04:23 AM
..... k
Old Apr 10, 2010 | 05:58 AM
B420a's Avatar
Originally Posted by DragonRacerX666
..... k
Dear DragonRacerX666,
I consider these as me you want to write it.?
I do not understand it unfortunately what you want to say how.
I would take a liking to it to ask, what does not like it what I wrote?
I do not speak well in English , but I understand it because of that,
I desire an additional beautiful day.
Old Apr 15, 2010 | 03:45 PM
JOSHDIZLE's Avatar
cool story bro!
