420A
Old Feb 16, 2006 | 03:55 AM
LIL Rez's Avatar
Default 420A
i was wondering wut a gs eclipse with headers, intake ,exhaust, msd wires, and bore out throttle body will run in the 1/4 mile..
Old Feb 16, 2006 | 08:45 AM
Default RE: 420A
16.s still
Old Feb 16, 2006 | 03:15 PM
slow420a's Avatar
Default RE: 420A
lol yup, thats about it, the thing is that a bore over dosent give you hp. Thats pretty much a waste of money if you dont build the motor high compression (turbo or n/a). With 2.5 inches in and out and the wires you may be able to see 16.5 if you can launch and drive correctly.
Old Feb 16, 2006 | 03:47 PM
Sanguinius's Avatar
Default RE: 420A
Reasearch dude. Find out what things work well and compliment each other to give the higher gains. Bore out the TB and do a port and polish on the intake, head, and exhaust. Get exhaust headers and then a bigger exhaust system. Look into an intake system get the supporting mods first THEN look into the boring out and all the more detailed mods. You wanna run faster find the stuff that has proven HP gains on a stock engine unless you're going to build the engine at the same time.
Old Feb 18, 2006 | 06:53 PM
eclipse99's Avatar
Default RE: 420A
best bet would be to turbo charge it. I've been looking for the same answer and i've found it through research. 420a are slow, unless you build the motor up ALOT!, or Turbo charge it...
Old Feb 18, 2006 | 09:24 PM
Default RE: 420A
ORIGINAL: eclipse99
well it can take boost on the stock motor im sure around 10 PSI I think a little more actually and it will be fairley quick at that point but if you want no worries a motor rebuild is a good idea
Old Feb 18, 2006 | 10:52 PM
slow420a's Avatar
Default RE: 420A
ORIGINAL: EMonz57
ORIGINAL: eclipse99
Right on the head, 12 psi is officially when the ring land blows. Hahn keeps the actuator spring set for 8 because boost always finds a way to creep a bit, expecially in an internally gated turbo.
halfasss101
Sep 4, 2007 02:35 PM
rucujo
Aug 30, 2004 01:21 AM
forza
Jan 10, 2004 02:33 PM
LowCloud
Jan 5, 2004 05:25 AM
kdombrovski
Jul 10, 2003 02:49 PM
