420a turbo
Old Mar 22, 2006 | 02:54 AM
eclipse27's Avatar
Default 420a turbo
Hey im in the process of rebuilding a 420a for turbo. Obvisiouly i have a budget and can't spend to much. Im shooting for 230-250 horses. What all upgrades will i need to do to ensure its not going to blow.
Old Mar 22, 2006 | 03:10 AM
5Tizzle's Avatar
Default RE: 420a turbo
completely replace all internals with ones that can take the power.
If u cant spend too much, its not gonna happen.
Old Mar 22, 2006 | 03:57 AM
eclipse27's Avatar
I know i need to replace the internals. I need to get my head redone? And what pistons and rods are good?
Old Mar 22, 2006 | 03:59 AM
5Tizzle's Avatar
dont have a 420a. Cant help you any further than that
Old Mar 22, 2006 | 10:29 AM
RCJr9186's Avatar
i'm no expert by any means, still well in the learning curve but this is what i've heard of - bore the block, forged pistons, rods, bearings, new crank won't hurt. i think the head can take up to about 8psi for a while but new cams, lifters, valve job should get you movin pretty quick. not to mention the turbo that you have to throw on there - please anybody correct me if i'm wrong or off track lol
Old Mar 22, 2006 | 11:13 AM
slow420a's Avatar
Your close, The hahn stage two kit runs at 8 psi which is just shy of 200hp. For 250ish your going to need to run at about 14-16psi.
For the motor the bare minimum that you need to replace are the piston rings, pistons(J.E. 8:6:1 compression), rods(eagle forged rods) and the upper and lower bearings. The block may need to be bored but if your on a budget you can use a ball hone which will do an ok job. If your not a mechanic I would recomend that you get it asyembled by a shop, their are special tools needed to press the pistons into the block. The crank is fine, the 420a dosent need a new crank unless you storke it. The head is fine for any psi, I would recomend replacing the valve seals while you have to motor apart their not too expensive and help.
Thats all you need, but if you get the hahn stage 2 kit, a bov, and a mbc with that fuel system you can only bring her up to 15psi, after that at a minimum you need to get bigger injectors, a safc(or something similar) a ingtion box with a ignition retard.... then a dyno tune. But if you get some bolton's like remove the cayt of the already 3" exaust that you have, intake manifold, 60mm tb, crank pully, adj. cam gears and a port/polish on the head you can make 250hp under the 15psi mark.
Lastly the budget and 420a turbo dont go togather, for a good asyembly and internals your looking at least 2000 bucks, and a turbo kit is 3000 bucks so your already in the hole for 5000 where you could probally sell your car and with that cash plus the 5g you could get a gst... and with 1000 in mods it will be faster then the 420a turbo and more reliable.
Old Mar 22, 2006 | 05:54 PM
Sanguinius's Avatar
Slow is the resident 420 expert lol... Listen to him and take at least some of his advice....
Old Mar 23, 2006 | 12:09 AM
eclipse27's Avatar
I've already put tons of money in my car and love the way she is. Im not trying to make it a speed demon, just want to make it have respectable horsepower. I'm not gonna do it cheaply, i obviously wanta do it right. I'd love to have 250 horses
Old Mar 23, 2006 | 01:03 AM
slow420a's Avatar
In that case I would recomend a howellautomotive.com bottom end rebuild, a hahn stage two fmic kit, bov, walbro 225lph intank pump, wide band kit, the hahn portfuler kit, crane ingtion box, a mbc, and a new clutch... then you will be able to reach 250hp with out a problem.
theironman
Apr 1, 2010 05:57 AM
halfasss101
Sep 4, 2007 02:35 PM
Eclipse
Sep 29, 2004 01:18 PM
LowCloud
Jan 5, 2004 05:25 AM
kdombrovski
Jul 10, 2003 02:49 PM
