4G32 Crankshaft same as 4G37?
Old Nov 9, 2011 | 11:02 AM
PharmD's Avatar
Default 4G32 Crankshaft same as 4G37?
Hi, I have a 4g32 engine from a Bobcat that spun a rod bearing and chewed up the crankshaft. I've searched all over the internet for a 4g32 crank to no avail. What I have come across is that the block to the 4g37, 4g33 are the same as the 4g32 only with a larger bore. My question is, would the crankshafts be interchangeable between these engines? My crank has the 5 bolt holes for the flywheel like the 4g33 and 4g37. Would a crank kit for say a 1993 Eclipse with a 4g37 fit a 4g32 engine block? Thank you for any help, I greatly appreciate it.
DragonRacerX666
1st Generation
May 10, 2010 06:29 AM
4g37 turbocharged
Sep 19, 2007 07:55 PM
mxer1
Feb 3, 2007 04:41 AM
turbobob
Jun 28, 2006 10:34 AM
duncombemu
Jul 11, 2005 08:44 AM
