4g63 stroker
Old Oct 29, 2006 | 08:31 PM
5Tizzle's Avatar
Default 4g63 stroker
Ive asked about them before, but i really just dont understand what the difference is between stroker and not. Do you gain more hp or torque with a stroker? Someone explain this to me.
Old Oct 29, 2006 | 08:45 PM
Default RE: 4g63 stroker
2.0L vs a 2.3L
TQ and HP plus faster spool on a bigger turbo
Old Oct 29, 2006 | 08:48 PM
paintballproam's Avatar
yes, a stroker is virtually building a larger motor. You would for instace put it a larger crank and there for increase the stroke of the pistion resulting in more cubic inch displacement. You will gain horse power and torque but the one of the main bennifits to building a turbo stroker is you decrease spool up time. The downside to a stroker is that they do not last as long as a regular motor. Say you wanted to run a GT35R or a fp3065 turbo on the street, it takes a good amount of exhaust flow to spool these guys up so you would see a quicker spool up time if you stroked your motor to 2.3l.
Old Oct 29, 2006 | 09:45 PM
there wont be a problem with life of the stroked motor. the biggest down side is usable RPMs. a built 2.0L and built head car far exceed the RPM capibilities of a 2.3L..the bigger the displacment the lower the REV limiter will need to be. so a 2.0L all built can rev to 9000 were a 2.3L at 8000 (these are not real numbers just making an example)
Old Oct 29, 2006 | 09:59 PM
when i was debating whether or not i wanted to build a 2.3l or a 2.0l I emailed some one at buschur racing and they said that strokers do not last as long
Old Oct 29, 2006 | 10:39 PM
5Tizzle's Avatar
so you would suggest just more bore? At what hp will the stock crank shaft fail?
Old Oct 29, 2006 | 10:42 PM
The first to fail would be the rods not the crank. The stock crank itself can take alot. ... as long as you dont crankwalk lol
Old Oct 29, 2006 | 10:49 PM
no i dont suggest more bore, the more you increase the bore the thinner the cylinder wall. look at it this way, you take a chevy 350 and bore it .030" over and you have just created a 355 engine, yay .3 more horse power at best.
Old Oct 30, 2006 | 10:34 AM
ORIGINAL: paintballproam
I know this but, he wont be getting near 100k anytime soon. so milage is not something I would worry about that is what I was saying
ultigator
Feb 25, 2008 01:50 AM
TheEngineer
Mar 6, 2006 11:30 PM
petro4411
Jan 30, 2006 01:21 AM
1398spdr
Jan 18, 2005 12:58 PM
antomx
Sep 29, 2004 02:32 PM
