4G63 vs. 4G63T
Old Jun 6, 2006 | 06:25 PM
BrunoBoy650's Avatar
Default 4G63 vs. 4G63T
lets say my 4G63T went out in my Gsx and i wanted to replace the engine. but i could get a 4G63 n/a for cheaper, can i bolt all the turbo and parets back up to the N/A or are they different? thanks
Old Jun 6, 2006 | 08:33 PM
93eclipsegsx's Avatar
Default RE: 4G63 vs. 4G63T
yes they are different.
Old Jun 6, 2006 | 08:37 PM
****... how different?
Old Jun 7, 2006 | 11:34 AM
slow420a's Avatar
ORIGINAL: Sebba
everything
Different: pistons, rods, head gasket, crank, cams, cyl head, and here is the kicker... the blocks are different [:-]. The 4g63 n/t has different size oil jackets restricting the flow of oil which would be bad for a turbo motor. So saying that, you cant even use just the block if you wanted it.
Old Jun 7, 2006 | 12:39 PM
Holy ****... i woulda thought like pistons and maybe rods.... but not all that!
Old Jun 7, 2006 | 02:24 PM
mysterio2099's Avatar
N/A is not turbos friend. hehe
Old Jun 7, 2006 | 03:26 PM
RCJr9186's Avatar
since it's on the same subject, i'm about to drop a 6 bolt into my 98 GSX. can i use the same stock turbo from my 7 bolt and bolt it up to my new 6 bolt???
Old Jun 7, 2006 | 04:08 PM
there is no point... the stock 7 bolt turbo is smaller (t-25) i would recomend getting a 14b
Old Jun 7, 2006 | 05:17 PM
RCJr9186's Avatar
i plan on upgrading my turbo but don't have the funds to do it right now... until i save the money for the new turbo would the t25 fit onto the 6 bolt?
Old Jun 7, 2006 | 05:53 PM
ORIGINAL: RCJr9186
the 6-bolt comes with the 14B turbo, its way better than your turbo
