4g64 problems
I have a 99 eclipse spyder 2.4
Press on the gas it sputters and dies I have replaced (some related some not) Alternator Transmission Starter Plugs wires and coil packs Battery Throttle body sensor Timing Fuel pump I have checked the Camshaft and crankshaft sensors O2 Starts fine, but when maf is plugged in and I press on gas she sputters and dies.when it is warm I can unplug maf and she will go down the road just fine ......what am I missing? |
replace the maf...its more then likely plugged up or fried
I have replaced it with a new one
Originally Posted by skyecatcher
(Post 296306)
And it didn't change anything
So that's why I am here Obviously if I had switched out the maf and it ran fine again I wouldn't have made a post |
reset ecu. (batt disconnect o/night)
