6 or 7 bolt?
Old Apr 1, 2007 | 04:27 PM
tjbiker031's Avatar
Default 6 or 7 bolt?
hey im back with yet another quick question. ok my 97 GST got the 4G63 engine in it. the 2 g's are the 7 bolts and the 1 g's are the 6 bolt right? im thinking about rebuilding my engine soon and i want to make sure that i got the 7 bolt, im sure i do but i just wanna make sure.
Old Apr 1, 2007 | 04:34 PM
Default RE: 6 or 7 bolt?
Well i can tell you right now that you do.
90-93 had the 6 bolt... and the 94 (still a 1g) had the 7 bolt. That is a common mistake!
94-99 had the 7 bolt.
Old Apr 1, 2007 | 04:38 PM
yea umm i wouldnt rebuild your 7 bolt. Buy a 6 bolt and build that up they are the good ones
Old Apr 1, 2007 | 04:40 PM
ORIGINAL: Sebba
7 bolt started in the 92.5 model year.so 93s have 7 bolts too if im not mistaken
tjbiker031's Avatar
well im kind of new to Mitsu's. whats the difference between the two?
Old Apr 1, 2007 | 04:41 PM
I was always told it was 93.5+ that had the 7 bolt.
I wouldnt swap the 6 bolt in. I just dont think its worth it... unless you plan on keeping the car for another 150k miles?
Old Apr 1, 2007 | 04:43 PM
It refers to the number of bolts that attach the flywheel.
The 7 bolt has a problem that is called 'crankwalk' its not massivly common but it destroys the engine. Some 7 bolts never experiance it.. and some do. There is no way of telling.
The 6 bolts are a little stronger.. and dont get crankwalk. But it is expensive to swap the 6 bolt into a 7 bolt car... like... 3000 expensive.. not including the cost of the engine.
Old Apr 1, 2007 | 04:48 PM
ORIGINAL: Sebba
nope its 92.5 and your retarded if you dont think a 6 bolt is worth it. Lets crank walk my motor more than once why dont we. Just a dumb idea
Old Apr 1, 2007 | 04:49 PM
tjbiker031's Avatar
i know its a stupid question and probably explained it a billion times but what is "crankwall"?
Old Apr 1, 2007 | 04:52 PM
ORIGINAL: Sebba
this post is complete BS sebba. IF you can do the work your self it is so freaken dirt cheap to swap in a 6 bolt. If your gonna rebuild a motor why rebuild a motor prone to blow up. its not that common??? well you tell me we have had like 5 members here in a year crankwalk there motors and it is a small forum. you do the math.
Where is silvercoupe we can ask how much he swap was and Ibet its not as expensive as youd think
