800 to 1200 idle help
Old Oct 18, 2007 | 07:43 PM
itsme71190's Avatar
Default 800 to 1200 idle help
i got a 95gs finally got it done. rebuilt head, new timing belt, water pump, and pullies.
i start it and i have to tap the gas while starting it so it wont stall.
it runs around 800 to 1200 rpms and bogs.
i think it is a vacuum leak.
any other suggestions?
Old Oct 18, 2007 | 08:01 PM
Default RE: 800 to 1200 idle help
Vacume leak. Hows your BISS?
Old Oct 18, 2007 | 09:19 PM
nick_200321's Avatar
is your check engine light on?? my car once ran like that, horrible, when one of the sensors under the thermostat broke.. the check engine light came on once it warmed up and if i didnt play with the throttle when it was first started it would stall.. and the throttle response was horrible.. does this sound similar?? just a suggestion
Old Oct 18, 2007 | 09:27 PM
itsme71190's Avatar
where is the BISS. on the throttle body correct?
the check light has been on since i got it. cause the guy b4 me cut off the cat. but yes it does have a delayd responce
Old Oct 19, 2007 | 06:01 AM
ok and one more queston, when you first start the car and hit the gas, does the rpm drop?? if do, pull off your sensor plugs under the thermostat and check the sensor.. might be broked lol
Old Oct 19, 2007 | 06:44 AM
itsme71190's Avatar
well i start the gas hit play wit the gas. but if i dont the car starts a 2k n drops to 800. then will die
Old Oct 19, 2007 | 07:16 AM
ORIGINAL: Sebba
sebba a 420a doesnt have a biss screw
Old Oct 20, 2007 | 09:01 PM
itsme71190's Avatar
ok now my car stalls. usually when im taking a corner
Old Oct 20, 2007 | 09:25 PM
ok.. and you still have the same issues.. did you check the sensor, im telling you those are some simptoms my car had, it was just a sensor under the thermostat, one of the prongs on it broke off
Old Oct 20, 2007 | 10:29 PM
itsme71190's Avatar
ill check that in the morning...
