95 eclipse front rotors
Old Oct 23, 2010 | 06:02 PM
95mitsu_eclipse's Avatar
Default 95 eclipse front rotors
I just got a 95 eclipse thats in need of a brake changes (pads and rotors) getting the pads and calipers off is easy but i cant get the rotors off. Do i need a special tool or is it just my car?
Old Oct 24, 2010 | 09:35 AM
yup the special tool is a sledge hammer....literally. Those rotors will seize themselves to the hub. You may even need to buy some rust eater (PB Blaster) or even a blowtorch to heat it up. But it may take alot of hammering to break it loose. Usually i just have one person turn the tire on the other side to have the rotor turn and then the other person just keep hammering the rotor
Old Oct 24, 2010 | 12:26 PM
No offence but my car has been hurt enough from the last idiot who owned it, it doesnt need me breaking more on it. Sum guy mentioned a hammer-puller, but there expensive and i need a way to get the same result
Old Oct 24, 2010 | 08:01 PM
i am totally serious about the hammer to the rotor. You are dumping the rotors anyway so nicking them is not gonna be a problem. That is the easiest way to break them loose. Go ahead and read around online, everyone will say take either a rubber mallet or if that isnt enough persuasion then a metal hammer. The only thing it will damage is the rotor. (that you are trashing. Like i said, PB blaster works wonders as well
Old Oct 29, 2010 | 02:39 PM
so after buyin the haynes manual, talkin to mechanics etc, i found the actual solution. there r extra slots on the rotor, insert bolt, tighten til it pops off. But when its rusted to death like in the car i bought, it came down to a hammer, so thanks lol
joeg
18
May 24, 2012 05:29 PM
vanjo
Feb 21, 2006 02:01 PM
Prophet
Aug 3, 2005 04:01 AM
throttlejockey
Aug 1, 2005 12:45 AM
PorscheNoSub
Jun 16, 2005 02:53 AM
