95 Eclipse,no fuel,no spark
Old Jan 25, 2010 | 09:59 PM
andyvr2's Avatar
Lightbulb High idle
Is the throttle cable binded an any way? and I'm assuming that this is the 1st time youve had/not pre-existing?
Old Jan 27, 2010 | 11:35 AM
kornfandude's Avatar
Throttle cable is fine.I think it maybe the Egr Valve.It's a problem i came across since I've got my car running
Old Jan 27, 2010 | 04:28 PM
andyvr2's Avatar
Well doesn't sound too bad. I hope it works for ya.
Old Jan 30, 2010 | 11:00 AM
Well replaced the Egr and still idles at 3,000 rpms.
Old Jan 30, 2010 | 02:57 PM
dsm1990gsx's Avatar
Egr valve wont cause a high idle, is the throttle plate closed completely?
Old Jan 30, 2010 | 05:10 PM
It looks like it is closed all the way.
Old Feb 2, 2010 | 05:18 PM
andyvr2's Avatar
Lightbulb
Haveyou checked the MAP sensor? this could also affect your idle.
Old Feb 2, 2010 | 11:32 PM
3000gt16's Avatar
Something else I would check is the throttle positioning sensor. I have a high throttle too (not as high though) and thats my next target is the tps.
Old Feb 3, 2010 | 04:41 PM
oh_what_up's Avatar
If the throttle plate is closed, air is still bypassing the throttle plate to cause the high idle. Check the BISS screw o-ring, throttle body gaskets, and the intake manifold gasket. If none of those are the culpret it may be the FIAV or the throttle seals going bad.
Old Feb 3, 2010 | 09:17 PM
Thanks everyone for the suggestions i gave up and had it towed to be looked at by a mechanic so far he has found no vacuum leak.next he is going to use a live data reader and see if anything pops up but first he has to fix my obd2 plug cuz it isn't getting a constant 12v.and i have already replaced the TPS,IAC Valve And EGR
