95 Eclipse RS clutch kit
I need a clutch kit for my 95 mitsubishi eclipse rs (2.0L, 2WD, Non-turbo). I checked ebay and found a store called buyclutch.com. They have great deals but I read some bad feedbacks in couple of other forums. I was wondering if you did business with these guys?
That would also be great if you can give me tips where to buy a clutch kit.
Thank you.
Thank you.
are you planning on keeping this car stock? if not are you planning on keepint it under 200whp? if so i'd just go w/ the stock clutch from an autozone. no need for an aftermarket clutch kit if ur not gonna be pushing a lot of power... and it IS very hard and/or expensive to make these cars powerful
i think i would stay away from a ebay clutch. Like RCJ said if you plan on keeping it stock just go for a stock clutch. From what i could find for you for aftermarket clutches, this is just off vividracing, Clutchmasters makes one for your car
$505.99 for a stage 1 clutch
$675.99 for stage 2, 3, 4
if u wanna go upgraded i'd stick w/ Spec clutches. they are cheap concidering tha they are performance clutches but won't kill your wallet. mostly b/c they only make kits suporting 350whp. you can get them at www.cimotorsports.net
