95 eprom ecu
Well my car currently has 6 bolt engine running with the 98 stock ecu. I finally got a 95 eprom ecu but i want to test it out before sending it to dsmlink. It should just be a simple swap correct? I dont have to swap injectors or plug wires.
RE: 95 eprom ecu
Swap it out and let her run down the block or wherever. I don't remember off hand whether or not you will need to rearrange the wires, but since you've got a 98....didn't you already swap the wires around? Unless you bought the prewired coil wiring or CAS plug (I forget which one is sold), then you don't have to worry about it.
You'll love DSMLink bro. The support over there is nice...but like any other board, don't forget to search it first, lol. I've sold a ton of issues just by searching and using the right keywords. |
RE: 95 eprom ecu
You will need to swap the plug wires. Put 1,4 on 2,3 and vise versa.
RE: 95 eprom ecu
The wires aren't swap at all.. i did it just to see wut happen and it doesnt start with it swapped. Going to switch to the 95 ecu when my car returns from the body shop all fresh and clean lol. Then dsmlink WOOOHh. thnks guyz
