95 eprom ecu
Old Jun 13, 2007 | 04:35 PM
Nubiebubie_GSX's Avatar
Default 95 eprom ecu
Well my car currently has 6 bolt engine running with the 98 stock ecu. I finally got a 95 eprom ecu but i want to test it out before sending it to dsmlink. It should just be a simple swap correct? I dont have to swap injectors or plug wires.
Old Jun 13, 2007 | 05:31 PM
silvercoupe97's Avatar
Default RE: 95 eprom ecu
Swap it out and let her run down the block or wherever. I don't remember off hand whether or not you will need to rearrange the wires, but since you've got a 98....didn't you already swap the wires around? Unless you bought the prewired coil wiring or CAS plug (I forget which one is sold), then you don't have to worry about it.
You'll love DSMLink bro. The support over there is nice...but like any other board, don't forget to search it first, lol. I've sold a ton of issues just by searching and using the right keywords.
Old Jun 14, 2007 | 04:34 AM
spinz4's Avatar
You will need to swap the plug wires. Put 1,4 on 2,3 and vise versa.
Old Jun 14, 2007 | 04:44 PM
The wires aren't swap at all.. i did it just to see wut happen and it doesnt start with it swapped. Going to switch to the 95 ecu when my car returns from the body shop all fresh and clean lol. Then dsmlink WOOOHh. thnks guyz
YUPinmyGST
Apr 19, 2008 10:37 PM
oh_what_up
Apr 14, 2008 07:19 PM
95420A
Jan 6, 2008 03:20 AM
clips69
Mar 13, 2007 12:48 AM
TX97GST
Aug 15, 2006 09:38 PM
