EPROM ECU Swap.
Old Aug 15, 2006 | 05:34 AM
TX97GST's Avatar
Default EPROM ECU Swap.
I have a 97 GST. What all do I need to do to swap in a 95 EPROM ECU? Or should I be able to unplug my old one and plug in a the EPROM. Problem is I tried that and it did not work, the car would not start witht the EPROM, but started right back up when I put the orig. ECU back in. Is there a step I am missing or is the ECU shot? I am using it to run DSMLink.
Old Aug 15, 2006 | 09:57 AM
Default RE: EPROM ECU Swap.
i would think that it should just swap in fine. I could be just a bad ecu. But you must know also that even with the ecu you still need to have it socketed so that the dsmlink chip can be used.
Old Aug 15, 2006 | 07:46 PM
slvr_eclipse's Avatar
When removing the ECU make sure that you are grounded. Any sort of spark from static electricity can ruin them. It is possible that that is what happened to the EPROM
Old Aug 15, 2006 | 09:38 PM
TX97GST's Avatar
I found the problem. teh 95-96 firing order is different than 97-99. I had to switch the plug wires. The ECU is already socketed for DSMLink.
YUPinmyGST
Apr 19, 2008 10:37 PM
oh_what_up
Apr 14, 2008 07:19 PM
95420A
Jan 6, 2008 03:20 AM
Nubiebubie_GSX
Jun 14, 2007 04:44 PM
clips69
Mar 13, 2007 12:48 AM
