95 gsx clutch replacement
Old May 8, 2007 | 03:15 PM
mcguffp's Avatar
Default 95 gsx clutch replacement
quick question, so im looking at buy a 95 gsx and it is going to need a new clutch sometime in the near future. I have heard that it would be a good idea to replace my flywheel while im down there, is this true?
Also I was thinking about putting in the ACT 2600 clutch kit and one of their flywheels (if i should), would i want the 6 or 7 bolt flywheel? sorry if its a dumb question.
Old May 8, 2007 | 03:18 PM
mcguffp's Avatar
Default RE: 95 gsx clutch replacement
nevermind about the 6 or 7 thing i figured it out.
Old May 8, 2007 | 04:55 PM
How much power do you plan on pushing. Or should i say, do you plan on upgrading the turbo. Because on a stock turbo the 2100 is fine for what you need and is alittle easier to drive. Also you dont need a new flywheel. Just getting the stock one resurfaced will work fine. But plan on spending about $600 to have it installed because its a pretty expensive install.
Old May 8, 2007 | 05:36 PM
mcguffp's Avatar
well, im defiantly planning on upgrading the turbo, i was thinking about the evo 3 16g. dang, more money i need to spend, haha.
Old May 8, 2007 | 06:57 PM
Natedogg89's Avatar
ORIGINAL: mcguffp
welcome to the world of owning a DSM...
Old May 8, 2007 | 09:28 PM
If you plan a few mild mods in the future then the 2600 is a good idea.
If your short on cash then resurface the flywheel. If you really want to splurge then get an aftermarket one. I recomend Fidanza
Old May 8, 2007 | 09:34 PM
mcguffp's Avatar
yea, I'm going to mod my car in the future, so I figured i would get the better clutch now, I'm pretty sure i dont need much more then the 2600. the 2900 just seemed like over kill for what i have planned. I kinda want to get a new flywheel, but there is always that money thing, so we will see. I will check the Fidanza ones.
Old May 8, 2007 | 09:39 PM
Wait, your clutch hasnt gone yet? Why would you spend money on it if its still ok?
Old May 8, 2007 | 09:44 PM
mcguffp's Avatar
it's in the process on dying. sorry if i wasnt clear.
Old May 8, 2007 | 09:53 PM
Oooh ok. Slipping?
