97 gst no power top end
hey, Ive got a gst spyder, through all gears at high rpm it doesnt feel like its pulling at all!
I bought the link to find out... Ive got like 90%+ injector duty at lie 13lbs of boost. I have a new 190lph rewire fuel pump eov3 16g turbo back exhaust bov, mbc, link. Ive been told the fuel filter could be a BIG PROBLEM is that so?! |
RE: 97 gst no power top end
Well it could be causing you to not get anough fuel i suppose.
Do you have a MBC set higher than 13lb? If so then maybe you have a little boost leak too. |
are you doing any tuning at all? Maybe you have a leak somewhere.
Im not sure if this will help but my car did that when I bought it. It would get it up to 4,500rpms, and just stop pulling and rpms wouldnt go any higher than that. I bought a fuel pump, injectors and SAFC-II and tuned it, everythings been fine ever since.
dsmlink?
stock injectors? did it used to pull or has it always felt this way? more story... |
and 13psi is weak sauce for a 16g, turn to 15-16, more than safe with a 190lph fuel pump and stock injectors
Possibly could ur clutch be slipping at higher rpm. Isn't that a sign of a clutch that need to be replaced?
ORIGINAL: Nubiebubie_GSX Possibly could ur clutch be slipping at higher rpm. Isn't that a sign of a clutch that need to be replaced? |
