97 gst no power top end
Old Oct 16, 2006 | 12:14 AM
a2rht930's Avatar
Default 97 gst no power top end
hey, Ive got a gst spyder, through all gears at high rpm it doesnt feel like its pulling at all!
I bought the link to find out... Ive got like 90%+ injector duty at lie 13lbs of boost.
I have a new 190lph rewire fuel pump
eov3 16g
turbo back exhaust
bov,
mbc,
link.
Ive been told the fuel filter could be a BIG PROBLEM is that so?!
Old Oct 16, 2006 | 09:31 AM
Default RE: 97 gst no power top end
Well it could be causing you to not get anough fuel i suppose.
Do you have a MBC set higher than 13lb? If so then maybe you have a little boost leak too.
Old Oct 16, 2006 | 10:14 AM
are you doing any tuning at all? Maybe you have a leak somewhere.
Old Oct 16, 2006 | 12:00 PM
burnmyeyes's Avatar
Im not sure if this will help but my car did that when I bought it. It would get it up to 4,500rpms, and just stop pulling and rpms wouldnt go any higher than that. I bought a fuel pump, injectors and SAFC-II and tuned it, everythings been fine ever since.
Old Oct 17, 2006 | 05:58 PM
DSMTalonAWD51's Avatar
dsmlink?
stock injectors?
did it used to pull or has it always felt this way?
more story...
Old Oct 17, 2006 | 05:59 PM
and 13psi is weak sauce for a 16g, turn to 15-16, more than safe with a 190lph fuel pump and stock injectors
Old Oct 18, 2006 | 01:45 AM
Nubiebubie_GSX's Avatar
Possibly could ur clutch be slipping at higher rpm. Isn't that a sign of a clutch that need to be replaced?
Old Oct 18, 2006 | 01:33 PM
ORIGINAL: Nubiebubie_GSX
well its depends if his rpms are rapping up or if the car is just not pulling
shownuff80
Dec 9, 2014 12:02 PM
metalmilitia
May 10, 2008 02:17 PM
dejved1
Mar 11, 2008 09:16 PM
poscar
Jan 11, 2008 02:09 PM
burnmyeyes
May 8, 2006 11:01 AM
