done everything...still smokes!
Old Oct 18, 2006 | 01:53 PM
DixonsGst's Avatar
Default done everything...still smokes!
ok i have a 97 Gst spyder w/ a few mods listed at the bottom. The problem that i noticed one day it was smoking blue smoke at idle and when i would take off at a stop light but not while i am driving it down the road. Blue smoke=oil burning. So i took it to my buddy that builds DSM engines all the time and he performed a compression test and said it was the rings. I agreed because the compression was off but i thought it was ackward because the car only has 88K on it. While he had the block apart i told him to go ahead and replace the rod bearings and main thrust bearings along with the rings. Well he put it all back together and its STILL smoking! So now hes putting new valve guides and seals in the head and were gonna see if that solves anything. Its not the turbo burning the oil either because it got rebuild 6 months ago and i pulled off the downpipe and its dry and the intercooler pipes are dry. If the new seals and guides dont solve the smoking problem what else could it be!!! The only thing i can think of is rings,valve seals, or turbo and if its not the seals idk what it is. Any ideas of what else to check out??
97 GST spyder
3in turbo back no/cat
injen intake
upper and lower piping
MBC
MSD wires
HSK ssqv bov recirculated
ACT 2100 clutch
other body mods.....
Old Oct 18, 2006 | 01:55 PM
Default RE: done everything...still smokes!
i was also thinkin headgasket but your going to change that anyway with the work your doing on the head... so... i dont really know. I wish you luck.
Old Oct 18, 2006 | 01:56 PM
well it would depends on how the #'s came out. But the guides and seals are probably the best bet.
Old Oct 18, 2006 | 01:57 PM
DixonsGst's Avatar
yeah i thought of that too...but we replaced that when we put it back together the first time and that wasnt it.
Old Oct 18, 2006 | 01:58 PM
DixonsGst's Avatar
lol damn that was fast i was replying to sebbas post
Old Oct 18, 2006 | 02:28 PM
ORIGINAL: Sebba
headgasket usually equals white smoke
Old Oct 18, 2006 | 03:53 PM
it can also be blue..
mrtony8
Mar 11, 2007 11:48 PM
mrtony8
Mar 10, 2007 08:53 PM
katinkid
Mar 2, 2007 03:37 PM
katinkid
Mar 1, 2007 09:00 AM
STACYYY23
Jan 18, 2005 10:23 PM
