top End
Old Jan 9, 2008 | 04:26 AM
poscar's Avatar
Default top End
Ok guys...We have here a 2.4(2g64) which smokes(from the exhaust) like mad! So,how do we fix this??? A new 4g64 head,(will it work?)etc...or what? I can't find anything good.Got any thoughts on how to tune this beast up?
Old Jan 9, 2008 | 07:12 AM
Default RE: top End
more info needed. Like what color smoke. What does it smell like. When does it smoke. Do you have a CEL?
Old Jan 9, 2008 | 01:31 PM
poscar's Avatar
Default RE: top End
I'm hearing,because i haven't started this thing yet,that the smoke is white,no smell mentioned.CEL dunno.Maybe you would...it's comp. stock.2.4 4g64,in a 95 galant...nothing aftermarket...um,maybe that'd help.
Old Jan 9, 2008 | 01:47 PM
Default RE: top End
well white smoke can mean a couple of things. Its either your car is running really rich. General culprits would be the Catalytic converter or the o2 sensors or a bad Mass air flow sensor. The other possibility is that its a bad head gasket. The way to tell if its this is the smoke would have a sweet smell to it. Much like coolant. And you might experience some overheating issues.
Old Jan 9, 2008 | 02:25 PM
poscar's Avatar
Default RE: top End
Dusty eclipse said it'd be an e-z fix.So,probably O2 or maf.Head gasket possibly,but still,wouldn't that still be e-z to fix?
Old Jan 9, 2008 | 03:04 PM
Default RE: top End
your buying this from dusty?
Old Jan 9, 2008 | 06:02 PM
bestwiseguy's Avatar
Default RE: top End
the o2 sensor or MAF sensor would be an easy fix. the headgasket however would not be easy and would be costly unless you did it yourself.
Old Jan 11, 2008 | 05:25 AM
poscar's Avatar
Default RE: top End
Not buying it from Dusty.We just talked about it sum.It's a 4 banger. Change'n the head gasket would be e-z to do myself. IF(big if) I keep this car ,it'll be getting new exhaust.So,there's that 1.All the sensors should be ez to...So,I should fix this 64,with 220,000 on it??? Seems like a lot o' miles.If I could find another I'd do a swap.[:@]
Old Jan 11, 2008 | 02:09 PM
dorian7's Avatar
Default RE: top End
That is ALOT of miles, if it has the stock motor you should probobly just consider a rebuild or swap
shownuff80
Dec 9, 2014 12:02 PM
metalmilitia
May 10, 2008 02:17 PM
a2rht930
Oct 18, 2006 01:33 PM
burnmyeyes
May 8, 2006 11:01 AM
SnSRacing
Jul 19, 2004 11:27 AM
