97 spyder Overdrive is out?
Old Mar 14, 2007 | 12:09 AM
Topdjdotcom's Avatar
Default 97 spyder Overdrive is out?
I just bought a 97 Gs spyder trans works fine unless you have the overdrive on then you can hear it slip on the highway you can get it to work a little. I drove it for a little bit like that then the Check engine light came on. thanks
Old Mar 14, 2007 | 01:54 AM
Manybrews's Avatar
Default RE: 97 spyder Overdrive is out?
the end clutch has failed.
it can be repaired/replaced without trans removal.
Old Mar 14, 2007 | 01:57 AM
really, I never get to hear good news, how much is a end clutch?
and what kind of job is the replacement
does this have anything to do with it http://www.altousa.com/np21.pdf
http://www.mirage-performance.com/Ec...endclutch.html
Eclipse
2.0L L4 AWD Turbo 1991-98
W4A33-1
Eclipse
2.0L L4 (Turbo) 1991-98
F4A33-1
Eclipse
2.4L L4 (w/o Turbo) 1996-98
F4A23
I have the 2.4 non turbo
Old Mar 14, 2007 | 01:50 PM
if you bring it to a shop then your looking at around 400-500
Old Mar 14, 2007 | 10:59 PM
the parts cost 85.00 ? have friends with shops an d the correct tools
Old Mar 15, 2007 | 10:55 AM
sounds good then. go for it
Ctrue2
May 1, 2012 08:09 PM
chmeftwc
Sep 15, 2010 07:33 PM
scitron
May 27, 2004 03:39 PM
glenn
May 13, 2004 04:46 PM
