98 eclispse GST clutch has no preasure
Old Oct 5, 2010 | 09:09 PM
11seconds's Avatar
Default 98 eclispse GST clutch has no preasure
I have a 98 eclipse gst and it keeps loosing preasure. I have changed the slave cylender and the master cylender and it still looses preasure. The weird thing is that as long as I pump it up it will build up preasure but when im driving it the preasure will continueously leave. So basicly when I get to a light or while im driving i have to pump the clutch up so that it builds preasure back up. Any help would be greatly appreciated.
Old Oct 9, 2010 | 07:24 AM
mxmikie's Avatar
you need to bleed the system
Old Oct 10, 2010 | 12:13 PM
11seconds's Avatar
I did bleed the system. Whenever it looses pressure and I pump it back up it builds pressure back up but not enough so basically I have to bleed the clutch everyday. But after I bleed the clutch it goes back to normally until I'm driving it. I just replaced the reservoir and cap. It seems to be holding pressure now. So my guess is that my cap wasn't creating a good seal allowing air into the system.
Old Oct 26, 2010 | 11:01 PM
oc_swap_guy's Avatar
Default My Sons Clutch
My son has a 95 that does the ooposite. His builds up pressure in the slave cylinder and it doesnt retract back enough to keep the clutch from slipping. Then I have to bleed it out for a couple more days of operation.
PIRI PIRI
Nov 27, 2007 11:03 AM
davedesmo
13
Sep 28, 2007 06:10 PM
davedesmo
Sep 27, 2007 08:37 AM
turbonatormr2
Aug 28, 2007 09:18 AM
EveIsle
Oct 15, 2006 08:08 PM
