98 spyder gst need some answers
i just got the car and it was already modified but i dont know anything about a tunner i usually drive muscle cars. i dont know where the turbo on this car is. or what size it may be or what kind of upgrade i should get. it has a NOS hook up in it. i need some help i dont know a thing about turbos
the turbo is right underneath the manifold coming off the front of the motor, if the car has a stock turbo ( which will be a t25 garrett turbo ) then that turbo will be good up to about 15-16 psi " i think "
stock set up has you running at 11 psi, you can get away with tweeking and messing around with the stock set up on the car till about 14psi, then you have to get bigger injectors, a bigger fuel pump, front mount intercooler.... the list goes on and on if the car has a nos hook up then the previous owner had some intentions on speed, id figure out what turbo is in that car a big 16g evo III turbo will be able to support about 400 hsp or so, thats probably a good turbo to look into, completely depends on your goals but you can pretty much do anything with the motor in that car |
Ok so you bought a car knowing completely nothing about what is done to it? This is not smart at all. You either need to contact the previous owner or find someone that knows something about cars and find out what exactly is in that car... That means fuel system, tuning device, turbo, exhaust, ect. before i can even help you
Originally Posted by TheEngineer
(Post 250098)
Well if you can get a good picture of the engine bay and some of the car (front, rear, interior) i may be able to do my best to tell you what you have. But there are alot of things i wont be able to tell you
