99 GST not starting/running
Old Sep 5, 2008 | 09:10 PM
mazdaboi88's Avatar
Default 99 GST not starting/running
i have a 99 GST that has kind of a dual problem. It will either not start or start and run for 30 seconds then turn off. I checked the fuel, spark, and checked for codes but i found no problems. I really need some advice on any other systems or parts could cause a problem like this!!!! Also: This is a manual trans vehicle that recently had its enging replaced
Old Sep 5, 2008 | 09:23 PM
dsm1990gsx's Avatar
Default RE: 99 GST not starting/running
Does it smoke at all? I was thinking a possibly bad coolant temp sensor for the hard start.
Old Sep 6, 2008 | 08:50 AM
mazdaboi88's Avatar
when u first try to start the car a little cloud of white smoke can be seen coming from the head but this will eventully stop
Old Sep 6, 2008 | 09:14 AM
sk8dudety's Avatar
sounds like a headgasket to myself... what color is the exhaust gasses?
Old Sep 6, 2008 | 12:57 PM
estraw's Avatar
do a compression test and come back w/the numbers
Old Sep 7, 2008 | 08:40 AM
start with the compression test like he said. But what about checking the alternator. Have you tried jumping it and leaving it to let the battery charge. See how long you can get it to stay running while still on the jumper cables
Old Sep 7, 2008 | 09:41 AM
I think this is electrical.
Could be ECU or cam sensor going out.... however, I would do a compression test like the guys said.
Old Sep 10, 2008 | 01:03 PM
mazdaboi88's Avatar
i did a compression test and all cylinders are averaging 150+psi
Old Sep 10, 2008 | 05:12 PM
dsm1990gsx's Avatar
Well you can assume the engine is in healthy condition. When it dosent start try spraying 2+2 into the intake and see if it fires right up.
Old Sep 10, 2008 | 06:37 PM
estraw's Avatar
take it to autozone and have them test your alternator, and also your battery for the hell of it. its free so why not
