About the GST's turbo
can anyone tell me how much psi it loads stock? and having everything stock, up to how much psi can I take it with a boost controler?
thats before I touch anything else. thanks for any help.
p.s. Does anyone know the name of that turbo, for example T4, T5, etc?... thanks
if you have a 1st gen gst you have a b14 turbo, if you have a 2nd gst you have the t25 turbo. the turbo runs 11-12 psi stock, and you can safely run 15lbs , but to be safe get a fuel pump first an 16 psi wouldnt even hurt. But considering the fact that you dont know what the boost is at im guessing you have no boost guage. boost controller + no boost guage = engine damage.
No stock they have these things around 13-14 PSI if you lucky you get a 13 PSI one so that when you put on your BC it will make it be a lot faster. You can run it at 15 PSI, but When I put my MBC on it is now running around 19 PSI because of a spike, but with other mods like exhaust and stuff you'll usually run over 15 PSI.
of course, i don't want to blow up the engine, so i'd install the gauge at the same time as the controller
