About the GST's turbo
Old Mar 14, 2005 | 09:01 PM
TurboDreamer's Avatar
Default About the GST's turbo
can anyone tell me how much psi it loads stock? and having everything stock, up to how much psi can I take it with a boost controler?
thats before I touch anything else. thanks for any help.
p.s. Does anyone know the name of that turbo, for example T4, T5, etc?... thanks
Old Mar 14, 2005 | 09:12 PM
1398spdr's Avatar
Default RE: About the GST's turbo
stock gst turbo i think is the t25, i wouldnt run more than about 10 psi on stock internals and fuel...........
Old Mar 15, 2005 | 01:23 AM
DSMTalonAWD51's Avatar
if you have a 1st gen gst you have a b14 turbo, if you have a 2nd gst you have the t25 turbo. the turbo runs 11-12 psi stock, and you can safely run 15lbs , but to be safe get a fuel pump first an 16 psi wouldnt even hurt. But considering the fact that you dont know what the boost is at im guessing you have no boost guage. boost controller + no boost guage = engine damage.
Old Mar 15, 2005 | 04:55 AM
1398spdr's Avatar
i thought the stock turbo ran 7-8 psi, as you guessed im n/a...............
Old Mar 15, 2005 | 08:02 PM
vertstanggt's Avatar
Def get a gauge before you do a boost controller, that's def a bad idea, it's worth the extra money for the gauge to not blow up your engine.
Old Mar 16, 2005 | 12:37 AM
of course, i don't want to blow up the engine, so i'd install the gauge at the same time as the controller
Old Mar 16, 2005 | 10:38 AM
nate5023's Avatar
No stock they have these things around 13-14 PSI if you lucky you get a 13 PSI one so that when you put on your BC it will make it be a lot faster. You can run it at 15 PSI, but When I put my MBC on it is now running around 19 PSI because of a spike, but with other mods like exhaust and stuff you'll usually run over 15 PSI.
Old Mar 16, 2005 | 11:38 PM
NO stock they run 11-12 psi , for the 2nd gen eclipse the stock BOV leaks at around 12-13 psi anyway
Old Mar 17, 2005 | 03:53 AM
I figured that's what you were planning on doing. That's what I'll probably do when I get some extra cash to play with.
baker_sk8er37
Oct 14, 2006 10:38 PM
Kahuna
Aug 22, 2005 08:18 PM
Knaackers
Oct 20, 2004 10:53 PM
98GstSpyder
Jun 10, 2004 11:11 AM
97greenRS
Apr 24, 2004 02:19 PM
