-   -   ABS problems (https://mitsubishiforum.com/forum/2nd-generation-63/abs-problems-2966/)
97GS NORWAY Jan 3, 2005 08:52 PM
ABS problems
After driving for a few minutes,my abs system stops functioning and the warninglight lights. Been to the local mitsubishi dealer,but they are not very helpful,since the eclipse is never sold in Norway and they don`t seem to know a dammn **** about the car..........The connections to the brakes seems to be ok,but where is the rest of the system located? I guess there must be a relay for the abs system somewhere......?
customizedrides Jan 17, 2005 12:33 AM
RE: ABS problems
It could be a lot of thihngs. Unfortunatly with a problem like that you have to have a wiring diagram and be good with a DMM. I would double check the connections at the wheels, they may be exposed soomewhere and shorting from moisture or the connection could be loose. Also unplug them and check for rust. The other thing you could do is check the ECU for any codes, that may be easiest. The relay for that is usually in the trunk or right under the hood. Good Luck!
1398spdr Jan 17, 2005 08:13 PM
RE: ABS problems
and something easily overlooked is make sure you have enough brake fluid........
97GS NORWAY Jan 18, 2005 07:55 PM
RE: ABS problems
Have had my ecu checked at local Mitsubishi dealer. They found an error code,but didn`t seem to hav a clue what it was about. The Eclipse has never been sold in Norway and they don`t have any data about it.[:@]
1398spdr Jan 19, 2005 02:02 PM
RE: ABS problems
if you know what the code is you can most likely find it online somewhere..........
vertstanggt Jan 20, 2005 03:25 PM
RE: ABS problems
Or try calling a dealership in the US, see if they might talk to you about it if you can't find it online.
