AGAIN!! !!
Old Jun 29, 2007 | 07:36 AM
  #51
silvercoupe97's Avatar
Default RE: AGAIN!!
What was voltage at idle? I'll have to look it up again because it's been since Januarary-ish since I last fiddled with mine.
I'll try and find some info on the 420a IAC check too. I couldn't find it in my Chilton's either. I'll look in my Avenger one in a sec.
Old Jun 29, 2007 | 07:51 AM
  #52
Default RE: AGAIN!!
Is you car still surging Lycan?
I can't find that info for the IAC Lycan. It's not in my Avenger book either. It just states that it's factory tuned and it should be left alone, lol.
I've got more resources though bro. I'll keep looking.
Old Jun 29, 2007 | 08:30 AM
  #53
Default RE: AGAIN!!
I just want to confirm that, yes, voltage goes down at WOT.
For the MAP..
Disconnect the plug and meaure the harness side. Voltage between 3 and ground with the igntion switch on, should read 4.7-5.2 volts.
Check continuity between 1 and ground and it should have continuity.
If you get anything other than on either one of the checks the MAP sensor is bad.
Look what I found in my service manual from Dodge
[IMG]local://upfiles/10268/4D029E43915646E5B9C48302DC2CF0D0.jpg[/IMG]
Old Jun 30, 2007 | 01:23 AM
  #54
lycan84's Avatar
Default RE: AGAIN!!
It only surges when it wants to it has never been consistant. its like it'll run fine for a week then the next it will run like crap. i dont get it. thanks for all your info and help coupe. ill check these in my spare time this coming week.
Old Jul 5, 2007 | 03:19 PM
  #55
lycan84's Avatar
Default RE: AGAIN!!
so i was told it is most likely the MAS. can somebody tell me how to get to it so i can try and clean it in a day or two. shes at it again.
TheEngineer
Apr 17, 2006 11:55 PM
Trader4Less
Apr 18, 2005 06:08 PM
Trader4Less
Apr 18, 2005 01:15 PM
jdmeclipse92
Oct 29, 2004 12:58 AM
ray@ipp
Aug 19, 2004 04:16 AM
