Air/fuel gauge
Those will do that. The wideband gauges are the ones that don't dance around.
What you're seeing is normal. It's picking up the front o2 sensor, which is constantly compensating as you see.
You're good, it's normal
Exactly. The narrowband O2 sensor you read from on the AFR guage reads from teh sensor that basically only shows a small set of readings. Either it's high, low, or basically in between and due to constant changes in fuel mixture and combustion gasses that voltage put out varies quite a bit usually. I know I'm doing a terrible job at this explanation but basically the O2 sensor puts out voltage depending on the reading. The reading always changes so the voltage always changes and the precision isn't very good. Like a 3 way switch. Imagine your head light switch= Off, Running lights, Headlights. It's in one of these positions but nothing in between. Maybe someone can help me here in this haphazard explanation...
Looks fine to me, I understood ya
The thing about narrowbands is that it reads 0 to 1 volt, so that's basically on or off. While a wideband reads 0 to 5 volts and give an average of the AFR.
ORIGINAL: Simss
ah thats really crappy then, yeah its constantly going from lean to rich and its like wtf is the point of u bitch *** gauge!
The good news is that you see it early on and not later as you're trying to tune...although, you can tune with it during WOT pulls, but that's about it as far as fuel trims are concerned.
Your comment eases my concern of you trying to tune with it or relying on it...good on you bro.
