Air/fuel gauge
Old Nov 16, 2006 | 07:43 PM
Simss's Avatar
Default Air/fuel gauge
So i just hooked up my air/fuel gauge on my 99 gst
but the damn thing is going crazy! its like a disco frenzy! wtf? it keeps going to lean to rich and vice versa
what did i do wrong?
Old Nov 16, 2006 | 07:50 PM
silvercoupe97's Avatar
Default RE: Air/fuel gauge
Those will do that. The wideband gauges are the ones that don't dance around.
What you're seeing is normal. It's picking up the front o2 sensor, which is constantly compensating as you see.
You're good, it's normal
Old Nov 16, 2006 | 09:00 PM
Sanguinius's Avatar
Exactly. The narrowband O2 sensor you read from on the AFR guage reads from teh sensor that basically only shows a small set of readings. Either it's high, low, or basically in between and due to constant changes in fuel mixture and combustion gasses that voltage put out varies quite a bit usually. I know I'm doing a terrible job at this explanation but basically the O2 sensor puts out voltage depending on the reading. The reading always changes so the voltage always changes and the precision isn't very good. Like a 3 way switch. Imagine your head light switch= Off, Running lights, Headlights. It's in one of these positions but nothing in between. Maybe someone can help me here in this haphazard explanation...
Old Nov 16, 2006 | 09:09 PM
Looks fine to me, I understood ya
The thing about narrowbands is that it reads 0 to 1 volt, so that's basically on or off. While a wideband reads 0 to 5 volts and give an average of the AFR.
Old Nov 16, 2006 | 09:47 PM
Sanguinius's Avatar
That's basically what I wanted to say but I didn't want to quote incorrect voltages there.
Old Nov 16, 2006 | 11:11 PM
Simss's Avatar
ah thats really crappy then, yeah its constantly going from lean to rich and its like wtf is the point of u bitch *** gauge!
Old Nov 16, 2006 | 11:14 PM
ORIGINAL: Simss
LMAO
The good news is that you see it early on and not later as you're trying to tune...although, you can tune with it during WOT pulls, but that's about it as far as fuel trims are concerned.
Your comment eases my concern of you trying to tune with it or relying on it...good on you bro.
Old Nov 16, 2006 | 11:55 PM
Sanguinius's Avatar
Plain and simple it's a light show. Nothing more. Something for ricers to go Oooo looky I have an AFR guage whatchu got? lol
Old Nov 17, 2006 | 11:16 AM
you cant even tune with those at wot because so what it says your in the "green" during WOT. What the hell does that mean. It still tells you nothing
Old Nov 17, 2006 | 07:09 PM
That's true, for some reason, I was thinking that some of them had a numerical value on them.
