All Cars That Have The 420a Motor
Old Oct 18, 2007 | 12:07 PM
kenlrw39's Avatar
Default All Cars That Have The 420a Motor
well i recently found out that i broke the locking pin that holds the cam gear in place on the intake camshaft. well i need to know what cars have the 420a motor and if i would beable to interchange the camshaft or any other parts.
thanks
Old Oct 18, 2007 | 02:00 PM
Wi_Fibre's Avatar
Default RE: All Cars That Have The 420a Motor
SOHC - Currently used in the Neon and export PT Cruiser; used for a time in the Breeze and Stratus. Similar to the DOHC used in the Neon, Avenger/Sebring, Mitsubishi Eclipse, and Eagle Talon; seriously considered by BMW for the 3-series. Basis for the 1.8, the 2.4, and the 1.4/1.6 used in the Mini. You can read more abou the engine here : http://www.allpar.com/mopar/2.html
DOHC - The Neon, Dodge Avenger, and Chrystler Sebring featured (as base engine on the Avenger/Sebring and optional engine on the Neon through 1999) the Chrysler-designed DOHC 2.0 engine. You can read more about the engine here : http://www.allpar.com/mopar/2dohc.html
Old Oct 18, 2007 | 08:08 PM
kenlrw39's Avatar
thanks for all the info.
Old Oct 19, 2007 | 03:22 PM
sk8dudety's Avatar
ur 420a is a DOHC by the way ;-), you should be able to find the same thing in a neon in a junkyard or somethin
Old Oct 19, 2007 | 05:05 PM
kenlrw39's Avatar
thanks for all the help found a camshaft from a 95 rs in the junkyard and now i got evrything running again but now i have another question when i start it up the rpm goes up to 3000rpm and settles at 2000rpm is that normal and how do i adjust the idle?
thanks
Old Oct 19, 2007 | 09:32 PM
TheAdvocate's Avatar
No, thats extremely high.. You should be around 700-800 depending on your car and preference..
Not sure with the 420a(I dont think it does), but on the turbo motors, there a base idle adjustment screw by your throttle position sensor..
Old Oct 20, 2007 | 10:34 AM
nick_200321's Avatar
i doubt if this is it, but could your throttle possibly be stuck open a little?? your car is idling WAY high, just a suggestion
Old Oct 20, 2007 | 11:01 AM
kenlrw39's Avatar
i checked my throttle and seems fine could it be the tps cause when i rev it the rpm takes a while to drop back to idle.
Old Oct 20, 2007 | 07:04 PM
kenlrw39's Avatar
i've solved the idle problem. my idle air controller was all gunked up so with the help of a little carb cleaner now my idle is sittin pretty at 1000rpms. now all i gotta do is change my throw out bearings. i'm goonna try to get some pixcs up of my ride soon. thanks everybody for the help.
Old Oct 21, 2007 | 05:11 PM
tjbiker031's Avatar
1k is still a little high...should be around 800 or so
