for all the gst's
Old Aug 11, 2007 | 10:10 PM
atown420's Avatar
Default for all the gst's
do you guys put oil in your car every one or two weeks. it seems like im adding at least 1-2 quarts every 2 weeks or so. is this common? i hope not
Old Aug 11, 2007 | 10:25 PM
Default RE: for all the gst's
No? Its fair to say you have an oil leak.... find it
Old Aug 11, 2007 | 10:32 PM
atown420's Avatar
oh **** well the best thing to do would be to get under the car and just look at everything
Old Aug 11, 2007 | 10:46 PM
Yep, oil leaks are usually very obvious
Old Aug 12, 2007 | 02:21 AM
spinz4's Avatar
Most likely the oil return line. Keep up on that **** man! Good luck.
Old Aug 12, 2007 | 03:46 AM
racerx55's Avatar
most likely evrything, its a DSM, what doesnt leak is what should worry you, lol
Old Aug 12, 2007 | 08:03 AM
A leak like that... im guessing oil pan
Old Aug 12, 2007 | 02:27 PM
atown420's Avatar
the oil return line coming from my turbo??? is that what you mean spinz4
are there any gaskets betweent the oil pan im hoping its just something cheap and not a crack in something that would be horrible
Old Aug 12, 2007 | 03:19 PM
Yes there are gaskets between it
Old Aug 12, 2007 | 05:17 PM
racerx55's Avatar
you should wash evrything off clean then run it and try to track down the source of the leak.
leave it run in once place untill you see oil drip on the ground, then shut it off, slide under and start looking up. or you can get under it with it running but i didnt tell you to do that... my luck youd run yourself over somehow[&:]
