Another damn clutch problem!!!! (Updated)
I tried adjusting the clutch pedal already with no results, and yes im using your flywheel. I took it to the shop today and hopefully ill have an answer tommorow. I need to get it on the road again since its my dd.
There is no way he has all of his gears with bad syncros. Come on now, thats just silly. This is probably one of two things:
1. You need to bleed the clutch fluid system to make sure there is no air in it.
2. Adjust the clutch pedal with the nut and rod on the back of the pedal. Alot of times with the ACT clutch this is required to have the correct grabbing point. So basically your clutch is not totally disengaging when your hitting the pedal to the floor.
EDIT: Oops i guess you already did the clutch pedal. Well then try and bleed the system.
Yea these cars are extremely quirky lol. I still have to get my damn door handle fixed, as it is now i have to crawl over my passenger seat to open my door lol.
