another problem.........lol auto rev? weird idle.
ok well my car usually idles at 750-800 but sometimes when im accelerating. and i let go to shift, foot not on gas , foot on clutch the revs stay put for a sec or two and then go down but slowly. and then seems to idle at 1200 for a good while, and then work its way down to 800-900.........i have no idea why this happens. it seems to stay high idle. but its also only at night when the air is cold. is this normal? it never used to do that. also i sprayed the throttle body things that moves (lol cant think of the name) with wd40 to try and see if it was sticking. and i guess it wasnt that. and then i put my foot under the gas pedal to try and pull up, and its not that either. please help.........thanks
-shane. and yes its a turbo lol
o yha when i first started it up, my fog lights were flickering...........and now they work they just did it when it first started up. i have no idea if this will help
RE: another problem.........lol auto rev? weird idle.
try taking your TB of and cleaning the inside with carb cleaner. I had the same type of thing and mine was just the TB coil that you were talking about, but maybe yours is just really dirty.
ORIGINAL: Dusty Eclipse
I agree, sounds like your throttle body is sticking... does the gas pedal feel loose as the car idles down?
even if my idle is normal most of the time, and vacuum never leaves 19-20, it can still be a boost leak? also wouldnt a boost leak cause me to have a type of cut when i drive?
it doesn't sound like a boost leak to me... can you still rev it and get on it as high (rpm wise) as you want?? it sounds either like a tb problem or some kind of computer problem b/c of the flickering fog lights... first suggestion, the free one. take the tb off, clean it, thouroughly, make sure it's free flowing and moving then see what happens. after that let us know what happened, if anything.
This will sound stupid... (and I may get flamed for it) but, try a different battery... My alternator in my TSi went bad, and thusly didnt charge the battery... we put a brand new batt. in it to get it a few miles away and park it at a friends house(his garage is bigger lol) towards the end, when the battery was giving up and almost fully discharged it had effects like that.
ORIGINAL: RCJr9186
