Anyone have any idea
Old Nov 28, 2005 | 11:03 PM
Timmay's Avatar
Default Anyone have any idea
I hooked my obd - 2 reader to my car earlyer cus my light was on and i got a reading that my ignition coil a primary / secondary circuit malfuntion and i have no clue what that means.
Old Nov 28, 2005 | 11:13 PM
Timmay's Avatar
Default RE: Anyone have any idea
and can anyone tell me if my 96 gs eclipse will most likely crankwalk or if it will happen or its just a matter of time. After reading a few articals on it makes me kinda fearful.
Old Nov 28, 2005 | 11:19 PM
Joel_CA's Avatar
Could you give the exact trouble code- not just the code description? FYI- The crankwalk issue affects only the 2.0L Turbo engines with manual transmissions.
Joel, CA
Old Nov 28, 2005 | 11:39 PM
slow420a's Avatar
That code most likley means that your igniton coil is bad. Like stated above you car wont crank walk.
Timmay's Avatar
thanks for that info i was worried because when i make a hard left turn sometimes my car trys to die but instantly rebounds and i do have a slight ticking noise that i just related to normal motor noise.
As far as the actual code i dont know for sure because i erased it and when i went to re retrive it it didnt come back up.
BrunoBoy650
Oct 17, 2008 10:49 PM
brucepa
Mar 6, 2007 11:09 PM
brucepa
Mar 6, 2007 05:41 AM
dirtracineclispe
1st Generation
Jun 20, 2006 03:16 AM
D3SOLATION
Apr 5, 2005 12:03 AM
