Apexi S-AFC II
Apexi S-AFC II
Aight.. I messed something up on mine. Was running well but Now im buring too rich and I cant get the car to run over 2200 rpm's without choking itself out.. Im wondering if anyone else is running this on there eclipse, and if you are, I could really use the settings that you are running yours at.. I have 750 injectors, 20g turbo, all hard piping, intercooler, 185 fuel pump.. Anyone have something close to that and running the safc II?
RE: Apexi S-AFC II
that was happening to me pretty bad. If you just base line set 2000- 6000 at -45% it should lean things out enough so you can drive it. You're going to want to get it retuned though pretty soon after. Also check to make sure that none of your wires are loose. This as well has happened to me. If the wires are loose the AFC can't send the converted signal to the ecu and its just like not having one at all. Hope that helps out
RE: Apexi S-AFC II
I got some settings off a site..
But with my setup a friend that has closer injectors gave me little closer numbers that should work...
Once I get the starter problem fixed IM gonna see how it does with the new settings..
RE: Apexi S-AFC II
like I said the settings I'm giving you are just to make the car drivable. That is how Slow boy racing base tuned my car without the dyno. I had to get my car towed up there because it kept choking itself out.
