Auto meter oil gauge??????
Ok heres the problem
I cant find the oil sensor in wich i should install the guage sensor
is there a whay that i can find a illustration or a walktrough of this installation???
thanks in advance
thanks in advance
I jsut did mine last weekend. Its a pain in the *****. Just to let you know you will need to get a 26mm oil pressure sensor socket. The plug has 8 sides instead of the standard 6. A bottle of pb. If you want detailed instructions go here http://www.forgemotorsport.com/conte...duct=FMDVMSP02 for a pic of the area, go here http://forums.2gnt.com/dcboard.php?a...id=77957&page= (note replace **** in the start of the link with 2 g n t, with out the spaces, for some reason this site hates 2g nt.com)
I did my install when I had the oil pan off, along with the front motor mount and the dp. So it was alot easier. If anyhitng take off the front motor mount(use a jack stand for the motor) it will give you enough room to use a socket rather then a wrench. And there is this blakc box that hangs behind the intake manifold, it also helps to move that out of the way.
2nd gen spyder 2 gauge pillar pod, autometer lunar boost gauge, and autometer lunar air fuel gauge f
mr casual
07-06-2006 10:59 PM
