awd conversion
Ok, first off, I swear I did a search. Everything I searched under gave me no results.
I am looking for a shell and someone mentioned they may have an AWD shell available. I have a 95 gst FWD vehicle. Can I swap out my motor and tranny easily? or does it require some modification? Any help or links to past write ups would be great. Thx |
RE: awd conversion
yea you can swap the engine over but you'll need a GSX drivetrain.
RE: awd conversion
wouldnt it be cheaper to just sell the gst and get a gsx? just curious
RE: awd conversion
Yea, atown, you might be right. But I am just looking into thiings to see what my options are. I haven't excluded parting out my current car and buying a new one.
Hy TJ, can you be a little more specific? I mean the whole drive train? Thx |
RE: awd conversion
like transmission back..
RE: awd conversion
What all does the gsx shell come w/?
RE: awd conversion
You don't need to swap out the motor to do an AWD swap, just the tranny. You will then ADD the AWD parts and remove the old gas tank and replace it with the AWD gas tank. That was the gist of it, here's the entire process.... http://www.automotivearticles.com/AWD_Conversion.shtml
Having the shell will be helpful. |
RE: awd conversion
very nice write up. should do it on a spyder. or would the body not hold up very well since its convertible
RE: awd conversion
Thx for the writeup link.
RE: awd conversion
actually i heard its easier because the frame is stiffer than the gst. alot of spyders gst's have done it.
