AWD Spyder: Motor Thoughts....
ORIGINAL: piachiii
BTW, do the Spyder owners think there is a lot of body flex? I was pondering a roll bar and some weld stiffening...
Thanks all,
V
Thanks all,
V
ORIGINAL: piachiii
Sorry about that......its a Spyder turbo.......
I have the rear suspension hung with the AWD gas tank. I am taking out the interior to do the drive shaft mounts and then I will drop in the AWD tranny and TX case....For the work I was thinking of doing the motor at the same time (stroker kit and EVO turbo with upgraded fuel manage) but I am not sure yet.....
Thanks all,
V
Thanks all,
V
Good luck with the project, no one will know what the fu3k is going on when you launch that bitch.
slow420a - LOL.....there is a nice write up already done on DSMtuner......I will get the link for you when it is back up...
There have been a few around and I am thinking of making the swap available at my shop.....
I am taking pics at every step.....I was thinking last night if I will have to change ECUs...
Any thoughts?
Thanks all...
Val
Any thoughts?
Thanks all...
Val
ORIGINAL: slow420a
No, a 4g63 ecu is a 4g63 ecu, your using all of the same sensors and waht knot
Thank you for the input. The are listed diff in the crach book and I was not sure if the AWD trans and FWD trans were different sensor/ECU wise.
Thanks all,
Val
PS Buying a 2.3 stroker from Jackson....any thoughts, bad or good?
Thanks all,
Val
get435 -Thank you for the advice...
Small story...
So I called Jackson, asked them for a quote to build the long block....told them I had 3-4000 to spend. I was ready to send them my 2g head for work.....
.................... They send me back by email a quote for $11,000!!!!!
Back to the drawing board....I was all fired up.....
V
Small story...
V
Fu3k the stroked block and get a 4g64 block http://www.dsm tuners.com/forums/showthread.php?t=152696
tw0000
12-12-2011 05:11 PM
