AWD Spyder: Motor Thoughts....
Old Dec 29, 2005 | 02:08 PM
get435's Avatar
Default RE: AWD Spyder: Motor Thoughts....
so i assume it is a spyder gst it has a 4g63 2.0L DOHC.
Old Dec 29, 2005 | 05:49 PM
DSMTalonAWD51's Avatar
ORIGINAL: piachiii
BTW, do the Spyder owners think there is a lot of body flex? I was pondering a roll bar and some weld stiffening...
Thanks all,
V
there will be more than a hard top eclipse, but not enough to be concerned. it works a guy on my local forum just finished one and rides great
Old Dec 29, 2005 | 07:04 PM
slow420a's Avatar
ORIGINAL: piachiii
Sorry about that......its a Spyder turbo.......
I have the rear suspension hung with the AWD gas tank. I am taking out the interior to do the drive shaft mounts and then I will drop in the AWD tranny and TX case....For the work I was thinking of doing the motor at the same time (stroker kit and EVO turbo with upgraded fuel manage) but I am not sure yet.....
Thanks all,
V
You sir are insane... I demand pictures, pictures of the finest sort. I have never herd of such a thing.
Good luck with the project, no one will know what the fu3k is going on when you launch that bitch.
Old Jan 1, 2006 | 04:51 PM
piachiii's Avatar
slow420a - LOL.....there is a nice write up already done on DSMtuner......I will get the link for you when it is back up...
There have been a few around and I am thinking of making the swap available at my shop.....
I am taking pics at every step.....I was thinking last night if I will have to change ECUs...
Any thoughts?
Thanks all...
Val
Old Jan 1, 2006 | 10:19 PM
slow420a's Avatar
No, a 4g63 ecu is a 4g63 ecu, your using all of the same sensors and waht knot
Old Jan 2, 2006 | 12:46 AM
ORIGINAL: slow420a
I agree, drive train isnt electroniclly controlled(unless you have some sort of ACD or DCCD which GSXs didnot) so I would assume he fine with the one you got
Old Jan 4, 2006 | 10:44 AM
piachiii's Avatar
Thank you for the input. The are listed diff in the crach book and I was not sure if the AWD trans and FWD trans were different sensor/ECU wise.
Thanks all,
Val
PS Buying a 2.3 stroker from Jackson....any thoughts, bad or good?
Old Jan 4, 2006 | 11:22 AM
get435's Avatar
just a suggesion it may be cheeper to stroke your 4g63 than buy a whole ne core as well.
Old Jan 10, 2006 | 10:55 AM
piachiii's Avatar
get435 -Thank you for the advice...
Small story...
So I called Jackson, asked them for a quote to build the long block....told them I had 3-4000 to spend. I was ready to send them my 2g head for work.....
.................... They send me back by email a quote for $11,000!!!!!
Back to the drawing board....I was all fired up.....
V
Old Jan 10, 2006 | 11:31 AM
slow420a's Avatar
Fu3k the stroked block and get a 4g64 block http://www.dsm tuners.com/forums/showthread.php?t=152696
Outlaander
Nov 14, 2018 09:50 AM
tw0000
Dec 12, 2011 05:11 PM
3000gt16
Jul 12, 2010 10:05 AM
03gteclipse
May 17, 2006 04:34 AM
GTAlander
May 18, 2005 12:28 AM
