bad day at the strip
Old Oct 31, 2006 | 09:12 PM
5Tizzle's Avatar
Default RE: bad day at the strip
aghhhhhh someone give me your 2 cents on this.
Transistor pack checks out fine.
There is power TO the coil, but nothing comes out, and my test says the coil is fine...gahhh
from what i hear its really hard to get to the crank shaft position sensor...
Old Oct 31, 2006 | 09:40 PM
paintballproam's Avatar
transistor pack
http://www.slowboyracing.com/more.php?id=1917&
Old Nov 1, 2006 | 03:18 AM
5Tizzle's Avatar
already tested that
its fine
Old Nov 1, 2006 | 10:16 AM
oh_what_up's Avatar
its not that hard to get to.. its just time intensive... just follow the instructions in your manual on how to change the timing belt and its down next to the crank sprocket.. I had to work down there three times this month so if you run into any snags just let me know.
Old Nov 3, 2006 | 03:57 AM
5Tizzle's Avatar
ORIGINAL: Sebba
ECU maybe?
Im thinking this may be a possibility now, but why would it just full on go out? any way i can test it?
Old Nov 3, 2006 | 08:05 PM
5Tizzle's Avatar
im not getting fuel either. Since both the ignition and fuel are part of the ecu...seems like thats what it is...right?
Old Nov 3, 2006 | 08:57 PM
5Tizzle's Avatar
oh yeah and i forgot to mention, the day it died, the coolant temp was especially high. All the way to red. Smelled a little like over heating too
Old Nov 3, 2006 | 10:32 PM
shreff99's Avatar
I would almost bet it's the crank sensor..I had one burn out on a '97 Spyder GS that I used to have..it also broke the balance shaft belt..it just died without any noise or jolts or anything...I say crank sensor.
lhausi2
Jul 2, 2009 07:26 PM
Lil Evo
Jul 16, 2007 08:26 AM
GotBoost
Mar 3, 2007 03:09 PM
Jomojr
Oct 14, 2005 12:49 PM
silverspyder
Jul 7, 2005 05:26 AM
