bad radiator
where is it leaking. Is it a hose, or just a crack? Because you can do a temporary fix for it. I had to on my elantra and it worked great. It does look all that great but you could paint it if you needed to, to make it match a bit. But You can get the stuff cheap at any auto parts store. It will look something similiar to this when you go there. Its basically like a clay
![Name: 0931964.jpg
Size: 7.9 KB](https://mitsubishiforum.com/forum/attachments/2nd-generation-63/12039d1501526874-bad-radiator-0931964.jpg)
you used two tubes of it on what. You are supposed to use it on the crack itself. So if that is what you have then obviously its not a hose. But like he said. Have the car running and maybe try and squeeze the top radiator hose to see if you can get it to squirt out anywhere.
what year make and model. i just hapen to have one that i was gonig to put into my 99 eclipse gs but never got around to it before selling it. i bought it brand new from CIMotorsports
