Bad wheel bearing
RE: Bad wheel bearing
Dont drive to long with it bad. If soo it might turn into a more expensive repair. The wheel hub wont come off the axle. Me and Engineer had it happen. I couldn't find a place that sold just the wheel bearing. They come as a whole wheel hub. Its not a hard thing to do also. It just invovles taking of nuts and bolts. If you have access to impact gun, it would make it quicker. Tires, Brake calipers, rotors, then the wheel hub its self. If you cant push the axel in even after you hammer at it to get it loose then you have to replace it also.
ORIGINAL: Nubiebubie_GSX
my right rear wheel bearing
Neah.
To do the rear is a little more complicated b/c you have to *i believe* disassemble the rear brake assembly.
I'd pick up a manual before anything.
Dafatboy
07-14-2015 06:06 PM
damuddog
09-11-2010 07:27 PM
