Bad wheel bearing
Old Jun 9, 2007 | 10:47 AM
sk8dudety's Avatar
Default Bad wheel bearing
well... thats about it... my right rear wheel bearing is goin and i was wonderin if anyone has replaced theirs or not... if so how hard or involved is it? this is on a 96 rs
Old Jun 9, 2007 | 11:43 AM
tjbiker031's Avatar
Default RE: Bad wheel bearing
did you look it up in your Haynes or Chilton to see what is involved? im guessing it shouldnt be too hard cuz its not AWD
Old Jun 9, 2007 | 11:55 AM
Nubiebubie_GSX's Avatar
Dont drive to long with it bad. If soo it might turn into a more expensive repair. The wheel hub wont come off the axle. Me and Engineer had it happen. I couldn't find a place that sold just the wheel bearing. They come as a whole wheel hub. Its not a hard thing to do also. It just invovles taking of nuts and bolts. If you have access to impact gun, it would make it quicker. Tires, Brake calipers, rotors, then the wheel hub its self. If you cant push the axel in even after you hammer at it to get it loose then you have to replace it also.
Old Jun 9, 2007 | 01:39 PM
sk8dudety's Avatar
cool thanks
Old Jun 9, 2007 | 02:07 PM
I Drive Naked's Avatar
ORIGINAL: Nubiebubie_GSX
Not to be a smartass, but a 96 RS has rear disk brakes?
Neah.
To do the rear is a little more complicated b/c you have to *i believe* disassemble the rear brake assembly.
I'd pick up a manual before anything.
Old Jun 9, 2007 | 02:59 PM
sk8dudety's Avatar
yea its got drum brakes, i've already had em apart a little over a month ago to check the e-brake and all... but i'll definitely pick up a manual beforehand
Old Jun 9, 2007 | 06:48 PM
LOL woops haha. u can blame my umm lack of reading skills on that.. i was thinking front for some odd reason.
Old Jun 9, 2007 | 10:46 PM
Dusty Eclipse's Avatar
The front is a MUCH bigger pain in the ***... and are prone to failure...
Dafatboy
Jul 14, 2015 06:06 PM
damuddog
Sep 11, 2010 07:27 PM
rosco
Apr 5, 2007 12:01 PM
97MitsuMonSport
Apr 5, 2005 10:04 AM
Chris
Dec 6, 2003 04:22 PM
