Belt Squeel
Old Sep 29, 2003 | 09:04 PM
dadandcoach's Avatar
Default Belt Squeel
<font face="Verdana, Arial, Helvetica, sans-serif">Belt (timing?) squeels when car is started</font>
When the car is started, there's squeeling and it should be the timing belt. Is there an adjustment to tighten that can be done before replacing it ($600 estimate).
Old Dec 1, 2003 | 08:53 PM
oldmansgs's Avatar
Default Belt Squeel
<IMG src=smileys/smiley1.gif border="0">if the squeal is only for a few seconds it's probably just an accessory belt,try squirting some belt dressing on a/c belt and alternator belt.If it lasts all the time check belt tension and adjust if neccessary.If this doesn't work it could be 1 of your 2 timing belt pulley bearings going bad.The timing belt itself should not be making this noise,hope this helps.P.S.,why not change the timing belt yourself and save $550. ????
newguy2007
Dec 20, 2007 10:35 PM
andrew rs
1st Generation
11
Aug 3, 2007 09:19 PM
keithscianna
Jan 14, 2007 11:43 AM
agallardo
Oct 29, 2006 11:33 AM
CatKicker
Jun 15, 2006 12:22 PM
