Best spot for hole
Old May 18, 2007 | 05:14 PM
I Drive Naked's Avatar
Default Best spot for hole
What would be the best spot for putting a hole in the firewall so I can run my amp power wire?
(2g RS)
Old May 18, 2007 | 05:23 PM
jlh077464's Avatar
Default RE: Best spot for hole
Uhm i think there is allready one. let me go take a look and see where its @...
Old May 18, 2007 | 05:30 PM
jlh077464's Avatar
Ok not sure if tha hole was previosly drilled by previous owner or was already there but my power wire is ran thru a hole drilled by the battery on the passenger side at the far top left corner.
Old May 18, 2007 | 05:31 PM
jlh077464's Avatar
my 420a talon has a hole drilled in tha same spot
Old May 18, 2007 | 06:13 PM
sk8dudety's Avatar
my power cable on my 420a is run right by the battery on the driver's side, im pretty sure it's a factory hole in the firewall
Old May 18, 2007 | 06:57 PM
Theres a "hole" under the glovebox, but its too tight of a squeze.
Send me some pics guys.
I need ideas.
Old May 18, 2007 | 09:10 PM
you could run it though the fender instead if you didnt want to drill a hole. But you can basically drill anywhere you can see from the engine bay. Doesnt really matter
Old May 19, 2007 | 05:28 AM
silvercoupe97's Avatar
ORIGINAL: Joshewuhh
I need ideas.
Here's that hole you're talking about Josh. I used the same one..but remember, my motor is on the other side of yours.
From the engine bay..
[IMG]local://upfiles/10268/74991FA419EB4D5BB071CA9F87D88F69.jpg[/IMG]
The wire coming out of the right side is my wideband wiring. There's a slot big enough for it and kept me from putting another slit in the rubber boot.
Looking under the glovebox..
[IMG]local://upfiles/10268/5B83969B59CD4A91B8B4B8FE8AC5B3D5.jpg[/IMG]
Old May 19, 2007 | 05:03 PM
Thanks everyone.
Well...
When my amp arrives, i'll install it all and send pics.
Hell, I will even do an offical write up for all to see for future reference
Old May 19, 2007 | 06:03 PM
ORIGINAL: Joshewuhh
Thanks everyone.
Well...
you should have it in about a week
