Blower Motor
Old Feb 2, 2007 | 04:44 PM
ilovethekathryn's Avatar
Default Blower Motor
Ok, I know this is a boring question, but my blower motor has stopped working and I was wondering if anyone had any suggestions. Btw, it's VERY cold here...[&:]
Old Feb 2, 2007 | 05:13 PM
Default RE: Blower Motor
blown motor doesnt tell us much. What exactly is broken?
Old Feb 2, 2007 | 05:27 PM
Well, when I bought the car, the dealer supposedly put a whole new blower motor in it, and it has now stopped blowing. It's still getting hot, but not blowing. I know how to get back there to check it out, (it's a long, hard process) but from there, I am lost. I don't know if its just a loose connection or what.
Old Feb 2, 2007 | 05:32 PM
RCJr9186's Avatar
i'm confused... a blower motor usually refers to a supercharged motor... what year, make and model car do you have and what are you refereing to when you say 'blower"
Old Feb 2, 2007 | 05:41 PM
Isnt it a GST???
Old Feb 2, 2007 | 06:15 PM
Um, oops... I think I confused you guys. I have a '96 Eclipse GS-T, and I wasn't talking about the engine, I was talking about the heater/air conditioner blower motor.... Sorry guys!
Old Feb 2, 2007 | 06:23 PM
RCJr9186's Avatar
ahhhh thank you, i was about to become envious, i've only seen 1 supercharged eclipse ever, at NOPI last year and have always wanted one. but sorry i can't help on the AC/Heater, not my area.
Old Feb 3, 2007 | 12:34 AM
Joel_CA's Avatar
If you look under the passenger foot area- you can see the back of the blower motor (big round unit). There will a 2 wire connector going into it. Disconnect the connector and check for voltage and ground using a test light. The light should be dim at low, brighter and medium, and full intensity at high. If the light is working- your blower motor is bad. There should be 3 screws holding it into position. Simply remove and replace.
If there is no light at all, check your fuses to the HVAC system. Note that this time of year- it is VERY common for rodents to find their way into cars as a means of warmth and shelter. They commonly find their way into the HVAC tubes and attempt to nest there. Once the nest and debris gets caught up in the blowermotor- it can trigger and blow a fuse.
J
Old Feb 3, 2007 | 05:27 AM
silvercoupe97's Avatar
^ sounds pretty sane to me..I think ours are squared off though. Nonetheless..
I hope you don't have a critter in your blower though, lol. That would just be gross.
You guys are pretty funny with the "blower motor" thinking, lol.
Old Feb 3, 2007 | 05:56 AM
racerx55's Avatar
I had a mouse in my neon, i found it when i heard the blower motor start to vibrate horribly, then a few thumps & grinding noisesi had mouse mush to clean out of all the vents and heater box.[:'(]I found its back half in the fan still, the rest was pretty well ground up.
For your start by checking fuses, then do like was suggested and check the wires with a test light. even try wiggling the plug to see if it comes on.
BrianB
Dec 14, 2008 04:53 PM
smith_t240
Feb 19, 2008 06:02 PM
2000sport
Aug 30, 2007 09:01 AM
amit_ahuja83
Jul 18, 2006 11:40 AM
hiramabiiff
Jul 9, 2006 01:22 PM
