boost controller
Old Jul 22, 2007 | 12:12 PM
c577's Avatar
Default boost controller
95 talon tsi awd
ok so i baught a turbo xs boost controller from a friend but i hooked it up and turned it up and i heard some air rushing out of it so i looked at it and the rubber ring closest to the bottom is covering these two little holes and it will only increase the boost to 7 lbs, all the rest seems to be coming out of the holes in the side, n/e body know why? or what i should do about it? oh the type i got is the one on slowboy racing for like 78 bucks if n/e body has one please gimme some input
[align=left] [/align]
Old Jul 22, 2007 | 06:34 PM
Default RE: boost controller
which way are you turning the controller (CW or CCW)? And also where did you tap into. And did you install it correctly
Old Jul 23, 2007 | 01:48 AM
silvercoupe97's Avatar
Which way did you turn it? Counter-clockwise is supposed to tighten the spring and allow for more boost, btw. It sounds to me that you've got it too loose?
Knaackers
Jul 17, 2004 08:55 PM
Knaackers
Knaackers
Jul 13, 2004 04:16 PM
Knaackers
Jun 25, 2004 08:14 PM
Knaackers
Jun 25, 2004 06:01 PM
